Ga door naar hoofdinhoud
Model A1213 / 8, 16, or 32 GB capacity
216 Vragen Bekijk alle
iPod 1g not restoring. Shows error 1603.
My old IPod Touch hadn't been used for a long time. I guess it went to recovery mode. When i charge it, it displays the apple logo at first and then it eventuaally fades to black. i charged it for a long time and nothing happened. It never turns on. I connected it to my laptop. Now, after the logo it shows the USB cable pointing towards a CD with a beam note music thingy in front of it and ITunes pops up with a message saying that itunes is in recovery mode and needs to be restored and updated. I do as it says and after extracting files stage, it enters the preparing itunes for restore stage. When it reaches the end, the Ipod disconnets, the screen flashes white and then the ipod reconnects with the apple logo on screen which fades to black eventually. ITunes get stuck for 5 min on the end of preparing IPhone for restore stage. The serial number shows : n/a. and error 1603 pops up. I tried many times. The same exact thing keeps happenig. I tried with different user accounts, updated ITunes, Different USB chords, Checked the port (it looks beautiful) , and it keeps happening. Help Me!!!
PS: i also tried to put it in DFU mode, but it says ur device couldnt enter DFU pleasse try again later. (i have pics n videos of everything if u need it)
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Try downgrading iTunes to 9.2.x.
https://support.apple.com/kb/dl1056?loca...
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
Okay, I downloaded it and pushed restore, but a message pop-ups saying theat my PC isnt connected to the internet. I have i Double checked that i have good connetion, restarted the PC but still the same message keeps popping up no matter how mant times i try. What do I do?
door
Which version of Windows or Os X are you using?
door
I use Win 10
door
right -click the iTunes icon, select 'Properties'.
Choose the 'Compatibility' tab.
Set it to run in compatibility mode for Windows 7.
See if this fixes the Internet issue.
door
did you actually try this? or are you just making suggestions, we need answers not maybe this will work.
door
I had same problem with mine a long time ago, turned out to be the battery that was faulty, try replacing it, they are super cheap and easy to install.
Voeg je antwoord toe
IPodPrblmGuy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 1,649
