Ga door naar hoofdinhoud
Valve Steam Controller, released November 10th 2015. Model 1001.
19 Vragen Bekijk alle
One of my triggers works ok but got squishy
My steam controller left trigger works when you pull it but doesn't have that 2 stage feel to it. It's as though the piece stopping the trigger just before the 2nd stage is gone and it just squishes into the button. I like the controller and I want to fix it instead of buying a new one. Is there some kind of trigger replacement possible?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
you would be looking at a full logic board replacement. The haptic sensation from the second-stage push-down on the trigger occurs when the trigger assembly places pressure (from your finger) on an embedded metal tensile pad which will click when enough force is applied to it. There's no feasible way of removing and replacing the sensor as it's metal appendages are folded into the PCB board.
Your best bet would be to leave the warranty stickers (covering the three internal PCB screws) in tact and contacting steam customer service, otherwise you're probably looking at a new piece of hardware.
rip.
Was dit antwoord nuttig?
Voeg je antwoord toe
Mark Wright zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 140
