Ga door naar hoofdinhoud
De Nokia 3310, die in 2000 uitgebracht werd, is onverwoestbaar, de allersterkste telefoon ooit.
26 Vragen Bekijk alle
Why is my phone not turning on?
The phone is not turning on. Not even the screen or the led lights. I don't have the original charger so I'm​ using a 4-6V charger with 800mA output. When i check the voltage of the battery, it shows slight increase after a long time. So i know the battery is charging. Yet the phone is not turning on. What might be the reason for this?
Is dit een goede vraag?
7 opmerkingen:
Are you sure your doing everything right? This is a 3310. They dont die.
Also what voltage are you measuring on the battery. And did the charger work with the phone before? And when did the phone stop working?
door
Mine stopped as well,as soon as I put New some card and 8gb memory card in it,now not even charging with original charger
door
I mean New version of Nokia 3310
door
Slav, This is for the old version. Also, where do you live?
door
Yeap,later I saw,that this topic for old version,and I'm in uk
door
2 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
My phone went off with nokia sign on screen
Was dit antwoord nuttig?
Voeg je antwoord toe
Nikhil Anilkumar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 2,433
