Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
20 Vragen Bekijk alle
Battery replacement every 2 months
Hi,
I have an iPhone 5s for now 3 years and a half. The original battery lasted as long as 2 years and a half before dying, so I then replaced it by buying new ones on the Internet.
However, the new batteries I bought (3 or 4 for now) only last 2 months before dying too, so I got to replace them quite frequently.
During the first month of use, they usually work great and have a good capacity, but by the second month, their capacity drop very quickly and my iPhone doesn't start anymore.
Do you have an idea on the cause behind this? Could it be the logic board that is getting dysfunctional and draining the batteries very fast? Or am I just buying bad batteries?
Everything else works fine on the iPhone, I even tried a reset to make sure it wasn't iOS's fault but it didn't change anything.
Should I consider my iPhone dead or is it possible I only got bad batteries?
Thanks for your help :)
Is dit een goede vraag?
10 opmerkingen
There are 2 things. Either your iPhone is dead. Or the batteries your getting are very cheap. How much do you pay for the batteries?
door
Usually around 20 bucks each
door
Do you buy them from the same person? Or different sellers?
door
A better question is, where are you purchasing them from?
Have you tried an iFixit sourced battery?
door
Yea, they are 15 bucks at ifixit, for a genuine battery. Your getting ripped off.
door
5 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I would suggest a genuine iFixit battery.
iPhone 5s Vervanging van de batterij
iPhone 5s Battery
If this answered your question. Please hit the accept answer button!
Replace a 1558 mAh battery compatible with iPhone 5s.
5.92 Watt Hours (Wh), 3.8 Volts (V). Compatible with all iPhone 5s models. Afbeelding
Product
iPhone 5s Battery
$29.99
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
I would recommend using the ifixit battery since they are genuine. You never know with other re-sellers what quality battery you are getting and that is most likely the problem. I have pasted the link below to the part. I hope this helps!
iPhone 5s Battery
Product
iPhone 5s Battery
$29.99
Score 3
1 Opmerking:
@luffy343, the only way to get a real Apple battery is to go to Apple. Any other source is a 3rd party. However, iFixit has accountability as opposed to other sellers.
door
Voeg je antwoord toe
Ottomatik zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 158
