Ga door naar hoofdinhoud
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Digitizer connectors broken -
Hi,
I tried fixing my ipad 2 wifi screen and i broke the two digitizer connectors as i show in the photo. Please help me.. Should i change the whole logic board or what?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You should take it to someone that offers microsoldering / board level repair for iPads. That digitizer connector will need to be replaced by them.
Buying a logic board isn't the best idea when the connector could of been replaced by someone.
I do have a microsoldering technician that does replaces them but depending on where you are I may be able to refer you to the nearest one.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
felipassadore zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 85
