Ga door naar hoofdinhoud
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 Vragen Bekijk alle
Sync Issue and Buzzing Noise coming from controller
Hopefully someone else has come across this issue.
When powered on the controller has a buzzing noise coming from the speaker area. It will not sync with a PS4 or Computer via bluetooth.
Tried resetting the controller via the small reset button on the back, doesn't make a difference.
It works perfectly when connected via USB but the buzzing noise is still there.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
For anyone with this issue, it turned out it was an incredibly good fake controller. Weight was nearly identical, everything looked legit but on disassembling it it was clearly a fake. If you have the same issue your controller serial number is also likely 11201371012310 - turns out lots have the same serial number.
Was dit antwoord nuttig?
2 opmerkingen:
well turns out mines fake
door
My controller was fine until I dropped it
door
Voeg je antwoord toe
Brendan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 6,551
