makes a loud screeching sound when trying to start
Mine makes a loud screeching sound when trying to start 2007 roadking
Is dit een goede vraag?
Could be the bearing is gone in the end of the starter . Pull the starter and spin it while not engaging the engine to see if the screeching is in the starter or if it is in the engine. if its runs silent then the problem is in the engine if the screech continues when the starter is run when not in the bike means you need a new starter. Hope this helps
Was dit antwoord nuttig?
If it's screeching and not turning over the engine, then most likely the starter clutch is blown out. The part is available separately, and the starter motor has to be removed and disassembled to replace it.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 30
Altijd: 4,673
