Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De derde generatie HTC One-smartphone die voor het eerst werd uitgebracht in maart 2015. De belangrijkste herzieningen ten opzichte van het M8-ontwerp zijn de octa-core Snapdragon 810-processor en een 20-megapixel camera achteraan.
HTC One M9 G-Sensor problem, a solution?
Hi, I have a HTC one M9, few days ago the smartphone fell to the ground and since then the G-Sensor doesn't work. I have done the calibration using HTC code( *#*#3424#*#* ) but nothing!
I think it is a hardware problem, is there a solution?
Thanks for your time!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
There possibly is! Exactly the same thing happened to me and I thought it was time for a new phone. I assume you've tried to calibrate your sensors (go to 'help' - 'troubleshooting' - 'Display and buttons' - 'The display doesn't rotate automatically' - 'G-Sensor', then test and 'calibrate G-Sensor'). Apparently if you do this several times this can fix the issue, but it didn't fix mine. I then came upon the 'drop fix'. If you've dropped your phone, as I did mine, it can put the sensor out. So you use the same method to put the sensor back in again! Hold the phone about 6 inches above a thin carpet or pad of paper and drop it onto each corner in turn. Then drop it flat on its back and again on its front. Hey presto, mine started working again. Hope this helps!
Was dit antwoord nuttig?
Score 3
6 opmerkingen:
Thanks, mine started working again too!
door
Really glad to hear it, An. There's nothing worse than that sinking feeling of thinking you've broken your phone!
door
Awesome! It really worked. Thank you.
door
Glad to hear it Marco. Stay safe!
door
Brilliant! Another phone saved, another user comforted in the dread of having broken their phone! Thank you so much.
door
1 commentaar meer tonen
Voeg je antwoord toe
Valerio Tregatti zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 1,477
