Ga door naar hoofdinhoud
Vraag afgerond
famous crackbook problem , how to fix?
I'm having the famous crackbook problem. It's a fissure in the upper case, you can see in a lot of macbooks , see google images http://goo.gl/N6MhA
It happens at least with late 2007 A1181 macbook (I think more models are affected)
I want to know if I can buy parts of the latest macbook's (2009) and if this parts will fit on my model .
The affected parts are
Front Display Bezel ( wich makes the pressure with magnets)
And upper case ( wich is the part that cracks)
I can still try to call apple , but I want to know if can
ask for newer parts.( the ones that dont crack :) and look better)
I don't want to get the same parts , It's gonna happend again for sure in a few months. There is a lot of people reporting 3 changes , even more.
But my macbook is out of warranty period , so they(apple support) probably change 1 time. And then I will have the same problems.
What should I do ?
Is dit een goede vraag?
Voeg een opmerking toe
6 Antwoorden
Het nuttigste antwoord
I would talk to Apple and see if they will cover it for you. There is no permanent fix for this as far as I know, the replacement parts will have the same issue. I have noticed the replacements we get from Apple now include the lcd plastic bezel as well with the top case.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I agree, take it to the Apple store, and they will replace it for free. I've taken in at least a dozen and they've never refused. The solution for it not happening again is, well, be more careful with your laptop! :-)
door
I think Apple still replaces this Topcase and the Bezel with a newer model. Just verify with Apple Care and head then to the next Apple store.
Yeah that happened to my white MacBook too... as well as everyone I know who's ever bought that. I personally think it's a waste of money to buy the parts, they're expensive and it just happens again. You could try maybe gluing the pieces back, or maybe melting the plastic?
do you buy old macbook? im selling mine.
the problem is im in the philippines an we don't really have apple store here.......ugggh..... anyone wants o buy? i'll sell it now
http://www.philmug.ph/forum/showthread.p...
You have.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 2,591
