Ga door naar hoofdinhoud
Apple Pay not working - where is the antenna?
I replaced my backhousing of my iphone 7 as it had a huge scratch on the back.
Now everything works perfectly but the apple pay.. can someone point me where exactly the antenna is for the nfc?
The gps, celluer, bluetooth all work perfectly and i thought they all share the same antenna band at the top, but i think nfc needs something else connected as well..
The housing is probably not oem so the material could be causing this but does anybody have any suggestion on this?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Around the main camera, look for a flex cable that connects a screw post on the board to a screw post to the top bezel, usually stuck to the camera bracket as well.
Was dit antwoord nuttig?
Score 6
9 opmerkingen:
Am I right in assuming it's pretty much in the same spot on the iPhone 6S?
door
Slightly different, looks like the one on 7 wraps around the whole right side of the camera socket, instead of just a short cable.
door
Thank you very much for the answer. You mean the strip that screwed with the top right screw on the logic board and wrapped around the camera to be screwed to the top right of the housing?
If that is the case, that looks like placed in perfectly to the logic board and the new housing. Can you think of the reason why this isn't working?
I will try to put the entire thing back to my original housing to check nothing is broken tonight.
door
Check the screw holes and contact finger landing area on the housing, they have paint machined off intentionally to make them conductive. If the replacement housing did not machine off paint in this area, then the reception would be defective.
Also check the exact assembly sequence of the top right screw hole on the board. The spacer, screw hole, cable screw end and contact pad must be assembled correctly or the signal won't pass through. After assembly, you can use a multimeter to test if they can conduct power end to end.
door
This is very helpful! Thank you, Tom. I just put everything back in the original housing and everthing seems like working perfectly.
I checked my replacement housing and yes, it has the painting covering the screw holes and etc. Although the multimeter confirmed the conductivity only when i check inside the screw holes, I guess that was not enough.. what do you think?
I used sandpaper to scrape the paint off so hopefully i will have it working soon! I will only get to try installing all later this week so i will update you hopefully without any more question :)
door
4 commentaren meer tonen
Voeg je antwoord toe
Firo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 2,559
