Ga door naar hoofdinhoud
The BLU Life XL can be identified by its model number: L050U. This smartphone was released January 2016, has a octa/quad core processor, Wi-Fi capability and a 13 mega-pixel rear facing camera.
44 Vragen Bekijk alle
data access suddenly stopped working
I actually have a Blue Life XL. About a month ago, data stopped working and I assumed it was a provider issue. Two calls to them led to the conclusion that it's NOT them. All the rest of the family continue on with no data issue on their iPhones. T-Mobile offered little guidance as it is a non-network phone.
Was working fine for several months until non-wifi data suddenly stopped working and I don't know where to start in trying to fix it.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
First check the APNs:
https://support.t-mobile.com/docs/DOC-20...
If this is already configured, try a factory reset and configure the APNs again.
NOTE: BACK UP YOUR DATA FIRST!
I would also then try one of the SIM cards that you know works.
If this has failed, there is something wrong with the phone and you should look into a repair or replacement.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Great job to 4k rep! 6k to go.
door
This was a great help. I checked the settings and they seemed correct, so I went ahead and restored the factory settings and I'm good to go. I feel embarrassed that hadn't tried that already. THANK YOU!
Voeg je antwoord toe
Neil Grepke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 135
