deck belt won't engage blades
Took the deck off my 38" 12hp PowerPro so I could sharpen the blades. When I put deck back on, the belt won't engage the blades...too much slack. Is there an adjustment for this?
Is dit een goede vraag?
Donovan B, I looked through the manual and does not show any adjustment for the deck belt and I assume you have belt routing correct(links below have routing) as looks pretty easy compared to some, maybe recheck your deck installation, springs/arms/etc.. I new belt, either you were given the incorrect belt size MTD 954-0329A V-BELT .625X69.28, or that the pulley's may be badly worn or old belt stretched.
I posted links below to show the belt routing, correct belt# and the various spring positions. The 2nd link is where you can down load your owners guide/manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 18
Altijd: 1,250
2 opmerkingen
You are correct L Pfaff, this is a very simple belt routing and I had it right. My guess is that the belt is stretched; going to order a new one. Thanks for the answer!
door Donovan B
@donovanb,Donovan, Thanks for replying back, wish you good luck with your mower.
door L Pfaff
