Ga door naar hoofdinhoud
broken connector for the camera and FaceTime
The silver connection for the camera cable has broken off at the board. Is this fixable on a MacBook pro A-1398? If so where can I buy the connector. Its a flimsy connector that takes very little to displace from the board.
Ever since this happened my fans continue to run at high speed. I have attempted on several occasions the recommended resets by apple but this hasn't solved any of the issues.
Is dit een goede vraag?
Score 2
2 opmerkingen:
Did you figure anything out? Happened to mine as well. Thanks
door
Melted the connector. No sucess
door
Voeg een opmerking toe
1 Antwoord
I am assuming that you have a 15" Retina MacBook Pro model between late 2013 and mid 2015 - you wrote A1398 in the question but chose a different model to file the question under.
You can replace the connector, however, this will require soldering equipment and some experience with microsoldering. You can buy the replacement connector here: https://beetstech.com/product/isight-cam...
Was dit antwoord nuttig?
Voeg je antwoord toe
Kevin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 433
