Ga door naar hoofdinhoud
The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
Headset cable broken cannot rewire
So after using the HyperX Cloud 2 for like 7 months I cannot hear anything from the right ear cup.
This happened when I was playing CS:GO.
I played several times with the cable going up in the headband, that's why the cable broke. (Check image)
(It's actually the other cable going up in the headband that broke)
I tried to wire them back and plug it in. It didn't work because the green wire has a special coating ? (Check Image)
(Not the broken wire)
(The broken wire)
Now only the mic and the left ear cup is working, what can I do to fix the wire problem ?
I tried to wire them back together but it didn't work because of the special coating i'm guessing ?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You need to strip the coating. I suggest using a lighter to melt it off. I found that works the best. After its stripped, you need to resolder the cables together, which i assume you know how to do.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you so much, i'll try that today.
door
Can you not use the lighter to remove the special coating and wrap them together? The same as using speaker wire or does it have to be soldered?
door
Voeg je antwoord toe
musa_a zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 29
Altijd: 7,482
