@meganmk1 , Megan, If shift indicator is showing in Park and Drive at the same time, set the park brake and try starting car with shifter in neutral position. If it starts look at getting the shift linkage/cable adjusted or possible worn shifter. If no go have the battery and starter tested, check all connections and ignition fuse/relay. Some of the auto parts suppliers offer free battery and starter testing like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
1 Opmerking
Check out this thread, there's all sorts of similar scenarios, seems it can be a battery cable to the transmission, or even the car key that needs to be replaced:
1997 Honda Accord EX wont start
door derekl514
