How to repair dead lan port?
how can i fix dead lan port in my desktop? i just try to install a video card after that lan port its not working....
Is dit een goede vraag?
Is the LAN port on the motherboard or an adapter? If it is an adapter, try reseating in, make sure it fits securely and level with the motherboard. You can try pinging the adapter in a command prompt with "Ping 127.0.0.1" if you get a time out then the adapter is probably bad.
You can try updating the drivers, you will have to download the drivers from the manufacturer on another computer to a USB drive.
If it the LAN port is on the motherboard, check the BIOS settings for the Ethernet adapter. If the LAN port is on an adapter, then try deleting the network device in Device Manager, remove the driver and then scan for hardware changes.
If none of these steps work, you may be able to get another Ethernet adapter. Check to see if you have an open slot, determine what kind of adapter slot it is (usually it will be PCI). Ethernet adapters are fairly cheap.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 37
Altijd: 30,872
4 opmerkingen
Did you install the video card while the power supply was plugged in and not switched off behind power supply?
If that's the case then it's not really fixable.
door Ben
Is ther a way to fix it?
door vangeelbryan
I install the graphic card then may lan port didn't work already it can't access the network. How can I fix this?
door ryan ragojos
@ryan ragojos
What computer make and model and motherboard are you using?
What graphics card?
What LAN adapter - on board or on an adapter card?
What Operating System?
With out this information we can't help you.
door mike
