Ga door naar hoofdinhoud
De Sony Xperia Z5 Compact is een Android-smartphone met een 4,6" IPS LCD-scherm met een resolutie van 720 x 1208, een quad-core Qualcomm Snapdragon 810-processor en 2 GB RAM. Uitgebracht in oktober 2015.
Black-ish screen after lcd change
Hi!
I just changed the screen of an Sony Xperia Z5 Compact.
I bought the screen on ebay.
When the screen was changed, the phone startet up an vibrates as it should, but the screen is black. It's not totaly black, because it sends out a super dim light, so it gets a bit brighter, but still its about just black.
I tried to use another moatherboard i bought some time ago, but that did not work either.
So I think it is the screen. But the new screen does not look damaged, and the cabel dose not look damaged either.
I also think the touch works fine, cause i can manage to click buttons to make the phone vibrate, but i don't see what I am doing.
Has anyone had a similar problem? I bought another screen, but if you know something else it could be, then i'm happy to hear it!:)
Thanks!
Is dit een goede vraag?
1 Opmerking:
Did you disconnect the battery before anything else?
door
Voeg een opmerking toe
1 Antwoord
Sounds like a faulty connector on the screen, often when the flex cable is not seated correctly in the screen manufacturing process the lcd will display black but the backlight will still turn on. This problem could also be due to the lcd connector not being fully plugged in.
Was dit antwoord nuttig?
Voeg je antwoord toe
vemundholstad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 1,065
