Ga door naar hoofdinhoud
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146 Vragen Bekijk alle
Front Camera not detected and Rear Camera distorted
So my LG G5 has this problem, the wide angle rear camera doesn't work in the camera app because the camera app thinks it's the front camera, so I have to switch to the front camera in the camera app, and it'll show the wide angle camera. The problem with this is that it's all distorted. Not only is that, but the front camera may be broken, I want to confirm here, I checked the cameras in AIDA64, and it only shows the 2 rear cameras connected, it doesn't show the front cam at all, anywhere, as if there was no front cam plugged in. I was thinking if I should replace the front camera. Can anyone confirm or anyone else have this problem?
Is dit een goede vraag?
Score 1
1 Opmerking
Was the phone damaged? And how?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Unfortunately, in situations like this, there is no possible way to 100% confirm that this will fix the issue, unless someone has seen the issue personally before, and even in that situation, that person may have had a different issue causing the same symptom.
As a technician, my order of operations would be as follows for this issue,
1) Cashe Wipe/Factory reset
2) New front camera
3) New back cameras module
4) reflow on Camera Data Line
5) Motherboard
the most effective way to go through this procedure, would likely be to pay a technician to do this, however, if you insist on trying yourself, I would purchase from a retailer that allows returns. If you do this, you can buy all of the components, then return the ones you don't need. this will save you time in the entirety of the process.
Was dit antwoord nuttig?
Score 1
Same problem in my mobile instead of opening front it openss. Rear wide cam…in cam it shows unfortunately stoped
I'm very curious about how this turned out for you as I'm having the exact same problem with my G5! I've searched relentlessly and all I can find are posts regarding the focus issue with rear cam. Please update on how you fixed the issue if you don't mind! Thanks!
Voeg je antwoord toe
jamesbadan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 1,010
