Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
iPhone 6S Plus Main Camera, 3D touch and flash light Not working
I have an iPhone 6S Plus with some issues. Main Camera and 3D touch Not working at all, flash light Not Working too. I checked the motherboard and I see sigh of water damage but everything else works fine. Do I need to replace any IC to solve this issue? What parts do I need to inspect with the microscope and test? Maybe some parts (like Resistors, Capacitors or IC) burned. I would appreciate your help. Thank you!!!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Clean the board and replace any bad components.
Was dit antwoord nuttig?
Score 2
6 opmerkingen:
I cleaned the motherboard, how can I find the bad parts; I can't see any clear damage with the microscope. What parts needs to test with the multimeter; maybe a chip needs replacement or some resistors-capasitors-filters
door
Are any components blackened/burnt?
door
I don't see any black components near the main camera connector
door
What about pins on the connector? Are those burnt a little?
door
no, seems it is ok. I think the problem is on the camera chip.
door
1 commentaar meer tonen
Voeg je antwoord toe
johnfl21 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 199
