Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
LCD slowly goes bad after replacement and working for 3 wks?
On 3/20/17 I received my LCD screen and front panel assembly. I successfully replaced and fixed the iPhone5 but on 3/30/17 the screen slowly went black, from bottom to top. You can see a small bit at the very top, ~1/2mm, but other than that no screen.
You can see in the pictures when it was 1/2 bad but now it is the whole screen.
It still works BTW, if you know the passcode you can simulate the pattern and unlock the phone and use siri to call so I'm supposing that means the digitizer is fine...
Thoughts anyone? Bad LCD? Bad fuse?
Thanks,
Steve
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
100% Bad lcd order a replacement and install a new one
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Thanks. this was one I ordered from iFixit and replaced 3 months ago. I'll ping them.
door
Voeg je antwoord toe
Steven Weller zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 52
