Ga door naar hoofdinhoud
Unibody MacBook Pro models with 13" displays produced from 2009-2012.
4630 Vragen Bekijk alle
How can I identify what year an optical drive is from?
I've been working on macs for about 18 months now, and 1 thing that always frustrates me is replacing the optical drives. I often times can't get a replacement drive to work in a MacBook that I know worked in another MacBook.
I'm told there's a way to identify the optical drive to know exactly what year a1278 or a1286 it will work in, but i'm not sure how to do that.
Does anyone know how to identify that to make it easier to know which optical drives I have in stock will work with which model year MBPs??
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
PowerBook Medic is very good about compatibility listings. Do your search there using the model number of the drive.
Was dit antwoord nuttig?
Score 4
1 Opmerking:
thanks for that...
when I look up model UJ868A anywhere, i typically get the answer that they're compatible with all a1278 & a1286 model MacBooks & pros. but i've found that some of these drives work in some models but not others.
is there a better way to look this up or know?
door
Voeg je antwoord toe
dollartripclub zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 57
