Ga door naar hoofdinhoud
The Toshiba Satellite L675D-S7016 is a laptop with a 17.3" screen released in 2010. The serial number for this specific guide is YA364457K.
Space bar not working
My space bar didn't work so I replaced the keyboard and it still doesn't work. Any suggestions?
Is dit een goede vraag?
1 Opmerking:
Hi,
Just curious. Try using a USB keyboard and see if that works OK.
That way will prove it is either a hardware or a software problem
door
Voeg een opmerking toe
2 Antwoorden
Hey,
There is a possibility when you replaces the KeyBoard it was a malfunctioning KeyBoard. Its rare, but it happens.
I would say use a USB Keyboard and see if the spacebar works on that. and if it does, its just the keyboard. If it doesnt then it is most likely a software issue. and we can work form there.
Replacement Guide: Toshiba Satellite L675D-S7016 Keyboard Replacement
Thanks.
Keegan
Was dit antwoord nuttig?
I took it into a local repair shop and they found out that it was a driver conflict that was causing the problems.
Voeg je antwoord toe
Dennis Nelson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 1,083
