Ga door naar hoofdinhoud
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
127 Vragen Bekijk alle
Tablet changing date and Time
Hi, turned on tablet tonight, i noticed not getting messages from friends etc, i looked and seen it was showing 4th jan 2013. Restarted it, still same, went to settings and changed it, seems ok... is this a warning of any sort?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Date and Time Settings - Samsung Galaxy Note® Tablet 10.1
From a Home screen, tap Apps icon Applications icon > Settings > Date and time.
NoteIf Settings isn't available, ensure that the Apps tab is selected.
To use network-provided values, tap the following:
Note Enabled when a check mark is present.
Automatic date & time
Automatic time zone
If preferred, manually adjust settings (Date, Time, Time zone) as appropriate.
Note To manually adjust settings, Automatic date & time and time zone must be disabled (un-checked).
If desired, tap Use 24-hour format.
Tap Tap date format then choose an option (e.g., 12/31/2014, etc.).
This may be a flaw in this model. Many others have the same issue:
https://www.cnet.com/forums/discussions/...
http://forums.androidcentral.com/samsung...
Was dit antwoord nuttig?
Score 1
Doesnt seem like anythings wrong, just a odd glitch. Check the settings under date and time and make sure the box to automatically set date/time is selected.
Voeg je antwoord toe
leanne61 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 4,443
