Ga door naar hoofdinhoud
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Vragen Bekijk alle
In boot loop 5 or 6 times then goes black
Hi Guys.
OK i have a Samsung Galaxy S5 which has never had a screen replaced or ever been damaged.
When it was brought in it was just a blank screen the phone is on as i can hear when it rings gets messages ETC it also vibrates too.
I took the battery off so i could restart it it does start up & comes up with the Samsung Galaxy S5 start up graphic then loops sometimes 5 times sometimes 6 then the screen goes black.
When the screen goes black the buttons along the bottom light up fine when activated.
I can't tell if the backlight is on when its black i don't think it is.
Any help or suggestions would be greatly appreciated.
Thanks in advance.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hey Kenny, Ive run into the issue before ive found a temporary fix but it only works long enough to pull data off the phone the phone is pretty much screwed
Ive found that heating the proccessor with a heater for 8 minutes at 120C make sure you place the heat gun 3 inches above the chip and heat let cool and reassemble this has worked for me 90% of the time and will pull it out of boot loop for about a hour
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hi Stephen thank you i will give that a go later & let you know how it goes.
door
It sounds like an issue with Android itself, it might be soft bricked. Did you try to flash/install something?
2 opmerkingen:
Don't think so she said she has never had anything done to it
door
Reading it over now, I see what you mean. Sorry, I must've misread the question!
door
Voeg je antwoord toe
Kenny Leonard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 12
Altijd: 88
