Ga door naar hoofdinhoud
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 Vragen Bekijk alle
My battery life switches
I have a macbook air mid 2012.
Now it says that service is needed for my battery.
So we had the SMC reset and let it fully charge and let it fully discharge.
But first coconut said that my fully charge capacity was 74% after the cycle only 51% and after recharging back again at 73%.
Has anyone an idea what's wrong and how to fix it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
If you go to Applications --> Utilities --> System Report --> Power, it will tell you the condition of the battery. From the behavior (and considering the battery is over 4 years old), it sounds like the battery needs to be replaced.
Was dit antwoord nuttig?
2 opmerkingen:
That's the problem. The battery is new. it only has 24 cycles.
door
@dagmar, so I would get your money back. I think you have a cheap knockoff. I have seen this issue on really poorly made batteries. What is the model exactly of the MacBook Pro? Late or early 13" 2012?
door
Voeg je antwoord toe
Dagmar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 38
