Why does my screen have negative colors?
One day the colors on the screen of my Iconica B1 A71 turned negative. There are no settings to change this on the current version of android for this device (4.1.2).
Is dit een goede vraag?
Usually it is in Settings --> Accessibility --> Display --> Negative Colors.
If that doesn't work, enable Developer options.
1) Go To Settings --> About --> Tab "Build Options" 7 times until it says you activated developer mode
2) Go back one screen, you should see a new "developer options" screen
3) scroll down to color space and play with the settings there.
If either of these don't work, try a factory reset.
Was dit antwoord nuttig?
On my LG Stylo 3 android phone went to Accessibility-->Vision-->Screen Color Inversion is set to OFF
How can I return my phone as if it was new and the settings of taking a picture or just automatic everything comes up the same color as it is from the beginning I just need to reset my phone so my I can take pictures like normal
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 29
Altijd: 21,066
5 opmerkingen
Update your device. Theres probably an option in accessibility for it.
door Cameron
There is no available update for this device, trust me there is no setting on this version. I have taken the tablet to tech fixers and they could find nothing either.
door pete42
Try resetting the device. If you cant find an option. factory reset the device. This should rid it of whats causing the issue. Could possibly be a virus. Download AVG antivirus from the play store and run it. if there is no viruses detected, it probably needs a factory reset.
door Cameron
Will I Lise all my pictures
door Sandy
If you haven't found it. Look for color inversion. mine was under accessibility
door j.loyalty
