Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Vragen Bekijk alle
Question about screen replacement.
I bent a flex cable on my xracked iphone 6+ screen so I am ordering a new one. I'm lazy and don't want to grab the old lcd shield plate off my current screen and am ordering a pre assembled one. I plan to replace the home button to keep touch id but will I also need to replace the home button flex cable? I was unable to find any information about this thank
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
If you are buying a preassembled screen then you should transfer the home button from the old screen to a new one.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Yeah I know but just the home button or the flex cable aswell? If it incldues a home buton flex cable.
door
Preassembled screens already have the home button extension cable which is part of the back metal plate for the screen. You plug in the home button which has a cable coming from it into that extension cable. It's self explanatory when you see a preassembled screen.
https://d3nevzfk7ii3be.cloudfront.net/ig...
door
the flex cable should already come with your new preassembled screen
Only replace the original home button to the new screen will do the job.
Voeg je antwoord toe
Dylan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 77
