Ga door naar hoofdinhoud
The Toyota Camry is an automobile sold internationally by the Japanese manufacturer Toyota since 1982, spanning multiple generations. Originally compact in size (narrow-body), later Camry models have grown to fit the mid-size classification (wide-body)—although the two sizes co-existed in the 1990s.
Were is the camshaft position sensor located?
Hello I have a 2010 Toyota Camry 3.5 liter motor. I would like to know were it is located?
Is dit een goede vraag?
Score 2
1 Opmerking
I have a 1999 Toyota avalon 3.0 and am also looking for sensor.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
There are 4 Cam pos. sen. on the 3.5 , 2 on each bank, for their locations see the attached link.
Crankshaft position sensors are all located in about the same position on all cars. They all are on the end of the crankshaft usually behind the harmonic balancer on the front of the motor. They are positioned to get as close to the crankshaft as possible as they need to be able to almost touch the spinning crankshaft to work . Hope this helps
http://www.autozone.com/repairguides/Cam...
Was dit antwoord nuttig?
Score 2
1 Opmerking:
sorry misaddress that hes looking for a cam sensor not the crank sensor
door
Het nuttigste antwoord
Here is a thread on how to replace it with diagrams on where it is located.
http://www.camryforums.com/how-tos/a/toy...
Score 3
Voeg je antwoord toe
Bobby zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 75
Altijd: 19,868
