Ga door naar hoofdinhoud
Scientific calculator by Casio with 252 functions and full dot matrix display. It also features a Replay function and seven variable memory.
Why is my calculator showing a decimal as the answer?
Whenever I use my calculator, and do an equation, for an example, 2+2. It would always give a decimal as the answer when clearly it is not. For 2+2, it says 4.0 instead of 4. For 9.2+1.2, it says 1.0 instead of 10.4. I really don't know what to do because I have finals coming up soon.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
usually it is shift + 9 to reset all settings on a calculator to default
Was dit antwoord nuttig?
Score 2
Try SHIFT, then MODE [SETUP], looking through the menu and selecting the mode you want.
Score 1
2 opmerkingen:
How do I get a dot instead of a comma in my iPhone calculator?
door
Caoimhe, please create a new question on this in the main Q&A page. This specific question is on the Casio fx-82ES, so your question will not bee seen by our community.
door
just press shift 9, it puts all the settings back to normal
Yess this happend to me and the answer in press shift + 9 or shift , mode , 3 , = and again =
Voeg je antwoord toe
Vanessa Mendis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 31
Altijd: 15,492
