Ga door naar hoofdinhoud
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
20 Vragen Bekijk alle
Screen won't respond to touch or home button
I am having an iPad 2 issue (or my son does) . i tried to troubleshoot blindly and accidentally held the home button and the top power button at the same time. I got the main screen to show up.... but wasn't able to go further as the screen went black again after 5 sec but I did see it was 100% charged
What spacificly is my issue is the screen shows NO Response to Pushing the Home button or touching the screen. Or it's not consistent no signs of damage (no water or heavy drops) I can hear the ping sound when I plug it in and sometimes it will show a flash of blueish screen instead of the usual black when it's off.... is this like a game system 3 Blue rings?
Prior to any of this it was a little slow so I allowed the latest update to go through (version 9.3.5) from
That point I started with the bluish screen or a white flash.
After looking at many of helpful answers I did a successful hard reset in that I pressed the right buttons in the right order and time. The main screen was back BUT only for 5-6 mins in order for me to see I have version 9.3.5 (13G36) in the iPad 2. I than finished updating some games I already had and than poof it went black again.... tried to do the usual wake up steps nothing worked..... So I did another hard reset (success after it first made a photo sound) this time I turned it off myself (with the swipe option) figuring that would be easier on the system....
So my 2nd question is how many hard resets is acceptable before I end up frying the motherboard?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@momof2boys , Maureen, I do not think you have to worry about frying the mother board because of factory resets. There are different opinions on whether Two many factory resets will actually do any damage. Check the links below for more info.. After you factory reset your iPad, watch what you are loading back on to see what App, game,data,etc., makes your iPad not respond correctly and then delete the App, program,etc., and try. Good luck.
https://discussions.apple.com/thread/705...
https://www.payetteforward.com/how-to-ha...
http://forums.imore.com/iphone-6/345824-...
Was dit antwoord nuttig?
Score 1
6 opmerkingen:
How do I delete the newest update since that seems to be the biggest problem? I was able to do a restore using my old computer but not sure how to stop it from rebooting the newest i version? But yes I'll delete one of the games too as soon as the screen stays on for more than a second
door
Maureen, The link's below will explain how to prevent and remove updates, hope this helps.
http://www.iphonehacks.com/2016/08/delet...
https://www.imyfone.com/iphone-space-sav...
door
You have been beyond helpful with all your links and I followed them all but for whatever reason when I looks into the manage storage it didn't have the ISO option there only the basics mail, photos, safari etc I'd send a photo if I could but trust me it wasn't there.
door
Maureen, Since you had done a factory reset is it possible you did no iso updates. I am not sure if this differs from what you have already tried, it may get you into delete update, just do not reinstall maybe until later date.
Remove the iOS update
Go to Settings > General > Storage & iCloud Usage. Under Storage tap Manage Storage.
Find the iOS update in the list of apps.
Tap the iOS update, then tap Delete Update.
(skip for now)Go to Settings > General > Software Update and download the latest iOS update.
If you don’t see the update in the list of apps or if the issue happens again, you need to update your device with iTunes.
door
You will NEVER believe what actually worked... so I did another reset (unattached to iTunes this time) and the screen was jummpier than ever than I read something about iPhone when then went ISO 9 having the same issues and they recommended turning off auto-brightness!! It WORKED!!!
door
1 commentaar meer tonen
Voeg je antwoord toe
Maureen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 896
