Sensor for the AmazonBasics 8-sheet Strip-Cut Shredder.
I read the excellent description of how to remove the sensor as described for the AmazonBasics B0050BPWBQ. My question is where do I obtain a new sensor?
Is dit een goede vraag?
Score
0
Hi,
Is there a part number printed on the sensor board at all?
If so, you could try 'Googling" just the number to see if you get results.
door jayeff
Amazon covers the shredder for 1 year. If its still under warranty, just contact them to replace the shredder.
door S W
Unfortunately the shredder is several months past the one year date. Interestingly enough it was a warranty replacement for the same model that had failed with a similar problem. I suppose I should have bought the extended warranty.
door Robert J Johnson
In that case, you may want to hunt around on ebay for parts. However, if the shredder is only a strip cut, not a cross cut, I would recommend upgrading to a crosscut as its more secure. During the Iran contra hostage situation, the hostage takers were able to piece together shredded documents because the government used a strip cut shredder.
door S W
