Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
Can I use the LCD of a 2009 13-inch on a mid-2012 13-inch MacBook Pro?
Do they have the same connections to the logic board?
Are they exactly the same or was the 2012 one improved?
Thanks in advance
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
LCDs are the same, the lid assemblies are not. The full lid uses a different LCD cable, camera and wifi connection.
If you are going to remove the glass and swap the LCD though, it will work fine.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
Thanks for finding that. I was trying look for it in the repair guide except they aren't loading for me. I have fast wifi and I have a retina with 16 and a 512
door
@sherlock_holmes luckily I don't have to rely on the internet then, since mine is not too great :)
door
lol oh. but u r using the internet to ask the question
door
I'll make that exception to give advice and help someone
door
Thats good plenty good reason
door
Most probably it must fit. But pls do verify connector type at lcd end. If they are same then replacing connector wires will work. Connector end might b different type at other end.
Voeg je antwoord toe
Alex222 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 95
