Ga door naar hoofdinhoud
Repairs guides for the Fender Frontman 15r, a small, 15 watt, practice guitar amplifier. Model number: 022-1500-000.
12 Vragen Bekijk alle
Fender 15r amp has no response to cable.
I hadn't used my amp for awhile, so I plugged it in and was playing, and it was working great. I was messing with the drive button and was generally adjusting everything to relearn what it would do. At some point after using the headphone jack etc. etc... It now will not respond to plugging my guitar in. Here is the weird part it sounds like it has a mic plugged in to it. I can tap on the front panel and it sounds like when you tap on a mic. It doesn't pop or anything when you plug in the cable like it should. Any ideas?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Check the pots you may just need to clean them out with some contact cleaner example on what symptoms bad pots can cause
A better way to clean out your pots (more tedious)
Was dit antwoord nuttig?
Voeg je antwoord toe
Cody Teague zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 261
