Ga door naar hoofdinhoud
Support and repair information for the Xiaomi Mi Band fitness tracker.
Not charging at all.
I let my Mi Band go to 0% battery and now it won't charge at all. I see now on the web that I wasn't supposed to let it go to 0% but my instructions came in Chinese so I had no idea. PS I wouldn't buy anything from them again because their customer service leaves a lot to be desired.
Is dit een goede vraag?
Score 16
25 opmerkingen
You my man are AWESOME
This works I can not believe it I've the band 4 and the sister in-laws band 3 did this and I tapped it back side even front as it didn't seem to work then a few minutes later with it still plugged in to be a big bit more violent and it was charging sweet
door
Ya it truly worked. I just left my band uncharged for over a month and while I plugged it to the Power Point i felt like the band gave up on life . I tried tapping on the button 3-4 times and hey it started working. You should also try it will work.
door
I'm Chinese and I am very confused too...
door
M3 smart band charge nahi raha hai kya kare sir
door
M3 smart band charging nahi ho raha hai kya kare
door
20 commentaren meer tonen
Voeg een opmerking toe
12 Antwoorden
Gekozen oplossing
just hit it while its connected to the charger this will cause it start charging again
Was dit antwoord nuttig?
Score 43
55 opmerkingen:
Thank you .. it worked
door
What do you mean by hit it? Give taps on the touch sensor? Or something else?
door
I read this and told myself it couldn't possibly work. Picked up a pair of scissors and tapped it lightly on the end sticking out of the charger and the light on the device came on. When I looked at my phone, it said it was connected.
Wonder if tapping it caused quick on and off electrical shocks to it. I don't know, but it's charging now.
Thank you, Yossi.
door
i could not believe this it worked tapped slightly on the charger and band..started working..
door
I didn't expect it would work but It worked Yossi.. you are awesome..
door
50 commentaren meer tonen
Combine all the steps.
First Take A cotton bud and clean the Golden receiver of band. Then take Scissors (metal) and gently scratch the circles (Golden Points). Then push hard into the charger (tightly). Immediately plug in and it'll work.
Score 14
13 opmerkingen:
Wow, the cotton, then scissor scraping worked for me! Thanks!
door
this really did work for me. thank u so much
door
Wow! I’m so impressed with this hack. I got this band for my birthday last year, but due to COVID I didn’t use it and didn’t charge it for a year approximately. I was really sad that my birthday gift would be ruined but I tried this and it worked! Thank You so much! Everyone reading this, yes, it does work try it.
door
amazing Xiaomi hack
door
Seriously this works I don't know how but it works .....
door
8 commentaren meer tonen
Guys guys this thing happened with me too. And I am writing this comment right after fixing the issue and let me put it out for you guys really simply.
First of all you wanna leave it charging it for half an hour so that it could have some juice to jumpstart. Then you need to take a knife, scissors anything you want and gently scratch with it on the golden charging pad the surface of the band and charger for a while and immediately plug it to a USB source and thank me later on
Score 9
11 opmerkingen:
Take a scissor and tapped it lightly on the end sticking out of the charger and the light on the device came on. When I looked at my Mi band, it said it was connected.
door
%#*@ it's literally working
door
Ya worked for Me. Spanking has turned it On , my watch was 3 months dead ,but see few spanks and knocking while charging it is working as LIT . this Chini kam always need some kick to work properly .
door
In my the screen is not available
door
when i read the previous comments i felt likr what stupid $@$* people are talking about.. bit i tried as told to tap the back connecting end while charging.. and to my surprise it actually worked... Thanks guys!!
door
6 commentaren meer tonen
Keep the band with charger of mi adapter for 1day then you will see it starts again with full battery. Mine also the same issue then i followed the same way.
Score 2
1 Opmerking:
Really will it work..? I didn't charge my band for many months.. so if I leave that in charge for 1 whole day.. will it work..?
door
The solution to the problem is simple, take a wet cotton then rub for 1 minutes on the charging pins of the band, then charge it… voila!!!
Edit (2023): If still not working, just take a scissor or any metal and gently scratch the charging pins, this will remove the thin film formed on the charging pin due to sweat and moisture. Wipe it off with wet cotton or alcohol (if you have). Then try to charge it again. 🥳
Score 2
4 opmerkingen:
What i did was clean the conneting parts with rubbing alcohol.. Then charge it.. While charging, i hit the back (both ends) with the corner of my phone... And it works!
door
i did the cleaning part and hitting while charging but still not worked...how hard did you hit it?
door
it worked so well! thank you alot!
door
didn't work for me((
door
Whenever you are not able to see the charging indicator do not panic and the solution is simple.
  1. Charge your Band for 10 to 30 minutes, do worry if there is no charging indicator.
  2. Remove from charging and wait about 10 seconds.
  3. Charge you Band again, now you will the the charging indicator start to turn-up again.
Reason being when you allow your Band to dry to 0 basically the Band doesn’t have any power to show the indicator, by allowing the Band battery to run again short charge is a must..
Score 2
3 opmerkingen:
Wow its realy work
Thanx
door
I charged it for a couple of hours, removed and charged again but still not working
door
I charged it overnight and still nothing
door
Try cleaning the contact points of the MI BAND3 with a little cotton......... Try 2 3times and it may work..... Try pushing hard the charger and the Screen of the MI BAND 3……….##
Achei um conteúdo legal sobre isso no https://www.thegeeks.com.br
I had trouble in the past where cleaning the contacts with alcohol (both device and charger) fixed the charging issue.
Probably 6 months ago (maybe longer) my band wouldn't charge even after cleaning. I tried putting in fridge, tapping it, different chargers but it refused to charge. I put it up for a couple months thinking it was done for. I came back across it one day & plugged it in to show my bf how it wouldn't light up or anything BUT to my surprise it actually started charging. I was so happy because I'd been lost without it but I noticed the battery level would get to around 40% then the next thing I knew the band wouldn't be syncing data and when id plug it in it'd only have one light, like it died right after getting to like 40%. I could live with that but a couple mts ago it finally stopped for good I think. I'm pretty sure the battery is just done for at this point.
I had 2 Mi 3 bands which were not charging, usually when I press them hard against charger pin it will start charging. But this time it didn’t and i also ordered a new charging wire, same issue even after that. I lost all hope and searched for answers and saw this post.
Later I tried to tap the watch with hand cleaned with cotton buds everything but no output. After sometime because of frustration I started hitting the band and the charging wire with minimum force randomly using my tv remote . Surprisingly one of the band light up showing the charging symbol. Later I tried with the second band but it took a bit longer beating than the first band and now both started charging.
Thanks a lot for the answers in this post guys, it saved my day and 4000 bucks.
Meri battery problem hai mi band 3 ki charging krne ke baad half hours main Khata ho jati battery mujhe battery change karni hai to koi solution batye ya service center batye jaha repair hoti h
3 opmerkingen:
Does the watch make noise while charging
door
Does the watch make vibrio noice every few seconds while charging
door
How long it takes to charge if there was zero charge
door
When I plugged in after not using for 4 years, it said 100 percent charged and in a sec display went off. Now there is no sign of display, kept plugged in for 12 hours. No sign, is it dead?
Voeg je antwoord toe
Annette Engel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 39
Afgelopen 7 dagen: 274
Afgelopen 30 dagen: 1,234
Altijd: 141,234
