Ga door naar hoofdinhoud
This PC is a Dell Inspiron 3000 Series laptop with an AMD processor and a non-touch display. It's model number is 3541.
20 Vragen Bekijk alle
How do I get the on screen keyboard off of my touchscreen?
I have touch screen. My onscreen keyboard stays on screen all the time & I can not get directions how to remove it. It is a constant nuisance especially when I am typing anything. How do I get if off?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If you go to settings and find your way to keyboard there should be an option to turn in on/off. If you Using windows 10 go down to cortana and type in "on screen keyboard" and there should be an option to turn it on and off. If your on windows 7 the easiest way is to do control+alt+delete and near the bottom left there should be an icon. Click it and there should be an option for on screen keyboard.
Hope this helps and good luck fixing!
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Wait Cameron or @cam2363..I thought I had it fixed but nope. the answers u provided were helpful but I did look to see that I have Windows 8.1 version. I tried control+alt+delete which did pull it up as u noted, but then after what do I note to take it off my screen. I will be eternally grateful if u can fix this. Thank u for your time.
door
When you dt ctrl alt del, look for this thing that looks like a 3/4 circle with 2 arrows. When you find it, there should be an option for on screen kb, just turn it off and that should fix it.
door
Thank u forever Cameron or @cam2363..I have been trying to get problem fixed forever, & now I have!! Thank u so much for taking time to answer for me, & then again as a follow up. Have a great day!!
door
No problem! Its just what i do! im super glad it worked!
door
Voeg je antwoord toe
Karen Bruce zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 3,502
