Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Home button is overheating
One night when I checked the phone, the home button was burning like none before and slowly i started to feel unusual warm from whole iphone 6 plus but no temperature warming sign at time.
I immediately switch it off for good. About half hour later. I turn it on again. Everything seem to be normal, however it only last for 15mins. And home button is getting hot again. Now, touch id function is not functioning even after data factory reset.
After few experiment, I find pattern of issue.
  • when lock screen, home button will get overheat in 15 mins.
  • when playing phone, there is no unusual warm after first occurrence.
  • when I plug cable in USB, iphone work surprisingly normal no heat at all. But when I plug cable in socket, home button is getting hot.
Solution I tried:
  • data factory reset
Can anyone help to explain what could be cause of issue? or way to diagnose issue? I asked authorized apple repair center, they asked me to replace entire home screen despite that only home button have heat issue.
Is dit een goede vraag?
Score 5
3 opmerkingen
Is it plugged in? It could get hot near the lightning port when charging. Do you have any battery saver apps installed or similar?
door
@pccheese Forget to mention, when I plug cable in USB, iphone work surprisingly normal no heat at all. But when I plug cable in socket, home button is getting hot.
My phone have no any sort of battery saver apps installed so far.
door
My brother fell and cracked the screen around the home button and it heats up and it’s super hot and it does not stops a little bit when turned off and dead what should he do?
door
Voeg een opmerking toe
8 Antwoorden
Gekozen oplossing
Sounds like home button got liquid damaged to me.
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
Any way to retain touch id function when replace home button?
door
Nope. Only apple can reprogram replacement home buttons.
door
contrary to popular belief, co can retain touch id, but you need to have expert soldering skills. here is a tutorial: https://www.youtube.com/watch?v=8IjC7rbH...
door
I also have the same issue but with Samsung A(2016) with S Pen model my screen gets heated just above the home screen button
door
Check battery with coconut.
Do battery replacment on worn out part.
have you got solution? my iphone 6s has same problem as mentioned above.
2 opmerkingen:
me too. phone keeps showing "Unable to set up touch id" which is stupid cuz I don't have it set up to begin with.
door
U don’t have to have it setup bro my home button Touch ID is broken no matter if u use it or not it will show that message
door
I updated my iPhone to ios 11, but after some times my phone started to overheat. I've got a thread from Google, in which I have met the Standard Solutions of iPhone overheating.
Am also having similar problem the home button has been heating since last theee days can someone tell me the cause and give me solution to that please
I had experienced the same on 8-10 iphone 6 plus's . The issue on them itself was lying in the homebuttons themselves. Replaced all buttons and the stopped heating up. But ofcourse we lost the touch id functions. Ok, now back to the faulty homebuttons, I didn't find any shorts or anything unusual with the faulty buttons compared with fully functioning buttons from working phones. Thanks
My iPhone suddenly yesterday when it’s on the left side button near the home button gets really hot I try resetting, clearing the open apps,take odd refresh app and still nothing works
Out of curiosity have the people with overheating home buttons had their screens replaced? I have a iPhone 7 Plus that was perfectly ok until I swapped the broken screen for a non genuine cheap version. Now the button is overheating even if I use it on the old genuine broken screen. I have checked the button ribbon using magnifier and it’s perfectly ok. I have a hunch that apple have a check feature built in to blow the home button if non genuine screens are used.
Voeg je antwoord toe
Yong Qiang Zhu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 25
Altijd: 35,531
