Ga door naar hoofdinhoud
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
Can't open the case
No matter how hard I try, I can't separate the two parts of the iPod. It would help if I knew how the clips work and what the opening tool is supposed to do. Just pushing it between the two halves opens only a tiny crack andf doesn't spring a clip. Is the plastic front part meant to flex inward to release the clip? If so the plastic doesn't want to bend. Maybe it's hardened over time? So should I be levering downward or just pushing straght in? I'm baffled because others seem to make it look easy.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@ancestor it'll help if you can give us the exact model of your iPod. Yes to the way you want to use the opening tool. Sometimes you may have to help it with a small jewelers screwdriver, or as in the case of the Classic, a thin putty knife. Yes, it is a bear to open ...:-)
Update (02/23/2017)
Yes that is a 4th gen iPod Photo. A bit of a bear to open due to a very solid back cover. Check this guide to see see the clips and how to use the tool. I also use the smallest jewelers screwdiver I have to assist in prying it carefully apart.
Was dit antwoord nuttig?
Score 3
2 opmerkingen:
It's an iPod Photo 60GB Model Nr A1099 EMC Nr 2022. I think that makes it a fourth generation?
door
I accidentally disabled the auto e-mail function. Has there been a further comment?
door
Finally, got it open. The pry tools are useless; eventually careful use of a small jeweller's screwdriver forced the two parts of the case apart enough to get the pry tool in and work it round the sides.
Two tips: the orange ribbon cable to the headphone jack was both stuck to the metal case, and held down by a piece of black plastic tape. This required care to remove, using a jeweller's tweezers. Second, it's not worth while unscrewing the circuit board to free the battery lead - just cut the wires and pull them through. The hardest part was re-attaching the ribbon cable connector for the jack. I used a paid of angled tweezers.
Voeg je antwoord toe
Geoffrey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 534
