Ga door naar hoofdinhoud
Een microcontroller (ook wel een MCU voor microcontroller-eenheid genoemd) is een kleine computer die op een enkele metaaloxide-halfgeleider (MOS) geïntegreerde schakeling (IC)-chip is geplaatst.
6 Vragen Bekijk alle
How to use enbedded-microcontrollers?
Hey, boys and girls.
Yesterday I bought a MB90F882PMC-GSE1, an embedded micro controller manufactured by Fujitsu.
I'm so confused on how to use it, maybe it just a simple problem.
Your help will be appreciated. Thank you.
Is dit een goede vraag?
2 opmerkingen
Hi,
Why did you buy it?
What did you want to do with it?
Here is a link to the datasheet for the controller. Perhaps this will help you .
http://html.alldatasheet.com/html-pdf/20...
door
I second @jayeff's question.
These need to be soldered on something to work. What purpose were you intending for these ICs?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The best thing to do is return it as you really can't do anything with a raw chip.
Maybe you want to look at a Rasberry-Pi system. Slide down to the lower section of the URL to see all of the devices you can get and the additional I/O modules. I have two I've been playing with.
The community and material here is just great to learn and build anything you can imagine!
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
shayne zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 791
