Screen lifting on Z3 compact
Hi my screen is lifting, I've tried precut tape normal double sided tape, I've taped both the phone and the screen. Nothing I've tried actually makes the screen stay. What else can I try.
Is dit een goede vraag?
Tesa 61395 or Original screen adhesive. Tesa probably better.
Was dit antwoord nuttig?
Check the thickness of the screen with Digital callipers and compare it to an Original which is around 1.9 mm , as much as 2.1 mm will cause this problem. Also you need to use Original hot melt adhesive instead of that generic grey pre cut suff.
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 5
Altijd: 364
