Ga door naar hoofdinhoud
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
iPod Won't Turn on
My son has an iPod and it recently stopped accepting a charge. I've taken apart many devices before but wasn't sure where to start with figuring out what is wrong with this one. I figured taking it apart and putting it back together would be a good start (especially since he is a young kid and has likely dropped it a few times). Any suggestions or guides for how to diagnose?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Replacing the battery would be a good first step however it does require soldering. There is no specific guide to replacing the battery but you can use this one nonetheless.
If the battery doesn't solve the problem, then you likely have a defective charging circuit on the logic board. This can be caused by using non-genuine chargers.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
I think this will likely be the next step I take, thank you for your help and I will let you know if it works.
door
Does the charging port cable plug in fully without gap?
If not clean out blockage inside port with toothpick or equivilant.
Make sure to avoid touching the 5 charging pins in the port. They can only be pushed down and not pushed to the side.
Score 3
1 Opmerking:
Sorry for taking so long to get back. Unfortunately that didn't help. Thank you though!
door
Voeg je antwoord toe
armytrixter85 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 255
