Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Ghost clicks after 3 minutes of usage
On my iPhone 5s, to works perfect for first 3/4 minutes of usage.
Then it seddeny starts doing ghost clicks and non responsive.
(I also see some vertical lines on display)
Then I lock the device (turn off display), wait for 2 min Aprox. Unlock again and it works perfectly for next 2/3 minutes.
As the cycle goes on.
Is this a genuine bug or specially granted to me?
How can I fx it?
Already tried
Reset
Restore
Reboots
Re-fixing display and touch strips.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi,
It more than likely sounds you received a faulty screen, or you may have damaged it installing it.
Try another screen and see if that resolves your issue, as there is a lot of garbage being sold on the likes of eBay etc. :-)
Was dit antwoord nuttig?
Score 1
I recently had a similar issue on my iPhone 5. The glass had separated some from the LCD and dust had gotten in there. It would open apps, type gibberish in text messages, etc. Replacing the display assembly fixed it.
iPhone 5s Vervanging van het scherm
Score 1
Voeg je antwoord toe
Mehran zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 101
