My Xbox 360 wireless controler wont do anything.
So I got a used Xbox off Craigslist and some of the remotes had battery acid corrosion on them. So I clean them with lemon juice and now nothing happens when I try and turn them on nothing happens. NOTHING!!!!! Please help!!!!!
Is dit een goede vraag?
Were are the battery contacts and how do I know if they are bad? Does it make a difference if I'm using AA's or not?
door Parker Collins
Yes you need to use aa batteries, along with the battery shell that the batteries fit in to. The contacts are just the metal part where the batteries sit on top of. Make sure they are not corroded or bent otherwise the controller won't be getting power from the batteries
door John
Ok how do i know if the battery contacts are bad
door Parker Collins
