Ga door naar hoofdinhoud
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Vragen Bekijk alle
Callers hear a buzzing sound?
Recently replaced my dock port assembly due to a speaker issue. Since then I've been told by callers that they hear an intermittent buzzing sound. I've re-opened the phone to make sure the gold metal prong near the mic is touching the chrome bezel and it is. What else could it be? Did I receive a bad dock port assembly? Help!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I have seen this problem before and it was caused by a bad mic and or connection on the dock. Try cleaning that connection with some isopropyl alcohol or replacing the mic only if you are confident in your soldering skills. Or try replacing the entire dock (again). Sounds like you are getting weird feed back from the mic. Good luck!
“You will not be punished for your anger; you will be punished by your anger.” - Buddha
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Interesting signatures to your answers--welcome to the team. Ralph
door
Thanks so much! I'm trying that right now. Fingers crossed it works. :-)
door
Well...IT WORKED!!!! I cleaned everything and made sure the gold prong was touching the bezel and put it all back together...works GREAT!!!! :-) Thanks again!
door
Thanks glad to be on the team! I kinda like to let the geniuses speak thru me.
PS. Congrats on the successful fix!!!!
door
Umm does it work if I just clean the outer part of the speaker? My phone fell when I went in into a haunted house a few days ago and that is how the buzzing sound started what should I do I'm scared that if I repair it myself I will break my phone.. Any solutions?
Voeg je antwoord toe
Carrie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 2,354
