Ga door naar hoofdinhoud
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
486 Vragen Bekijk alle
Black screen with solid blue light after teardo, tried button restarts
Hi I recently took on a Samsung Galaxy s6 after a teardown but it's been given to me with black screen and a solid blue light which doesn't turn off, I've tried charging on Wall for a day, the charging led went from Blue to red after about an hour or so and started charging but the screen was still black and then I tried to turn it on again and it flashed a green/grey colour on the right hand side of the screen bit kind of faded to the middle and was black on the left, happened very quickly and I only just noticed it and the phone pretty much just did the same thing again..
I'm leaning to heat damage on the actual lcd because it looks like they've had a good go at taking it apart but I'm unsure as I thought the phone would still turn on and do everything as normal just with out any picture, specially without a solid blue light which makes me think it's something else.
Any input would be great as I've never come across this before and I have tried all the button restarts and so on possible to sort this and definitely think something needs replacing.
Is dit een goede vraag?
Score 2
1 Opmerking
this happened to me after i attempted a repair not sure what I did wrong assuming I somehow damaged the lcd did replacing it work?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Try new LCD first would be my method
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Yeah comes this week so will let everyone know if it works
door
Any update on this?
I am curious if the new screen worked?
Hi. I have the same problem. Did you get it working again?
1 Opmerking:
I held the power volume and power buttons... it worked!!
door
Voeg je antwoord toe
Dylan Swaby zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 3,604
