Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Model A1312 / medio 2010 / 3,2 GHz Core i3 of 2,8 & 3,6 GHz Core i5 of 2,93 GHz Core i7, ID iMac11,3
Is it possible replace CPU from i3 to i5 or i7?
I have imac 27" i3 (mid 2010)
Is it possible replace cpu to i5 or i7?
I have some information that i5 model replace to i7 cpu.
http://www.hardmac.com/articles/335/page...
I think i5 model is possible.
Is it possible i3 model?
Please helping me
i3 core is very slow~
Is dit een goede vraag?
Score 4
3 opmerkingen
is it worth or not? those that did the upgrade, still running well? does the fans can hold the temperature without any issues?
im thinking about upgrade to core i7 860 (or 870, dont know yet the exactly difference) but im afraid of overheating or something...
door Deel
Still good working.
No problem.
door Deel
Still good working.
No problem.
door Deel
Voeg een opmerking toe
13 Antwoorden
Filteren op:
Gekozen oplossing
It follows the same procedure as both are LGA 1156 (i3, 15 and half of i7 is, the other half of the i7 family is LGA 1366)
Was dit antwoord nuttig?
Score 7
5 opmerkingen:
Sorry, i can't english very well. Please note, if not better.
I knew that your answers. Except the just replace. My question is "Clearly recognize that it works?"
I can't understand this info(please check this site)
http://www.everymac.com/systems/apple/im...
door Deel
Yes it will work, the only difference between an i5 or an i3 is that the processor is different so you can swap it out and the logic board should recognize it and is and willy be fully compatible
door Deel
Thank you for answer to me!!
door Deel
So the connection points 'are the same correct?..
door Deel
Six years ago; needing to update now. /chuckles
door Deel
after 1 year i3 to i7 870 working very nice
Score 3
8 opmerkingen:
me too. No problem.
door Deel
Are there any updates on the successful upgrades?
Are they still performing well?
I am hoping to do the same to my mid 2010 iMac i3 since the price of the i7 870 has fallen so much.
== Update ==
Thanks to both Jooyoung and Renato for your replies.
I successfully switched the i3 550 processor for the i7 870 and dropped a Samsung 830 SSD in there as well for good measure.
Machine is working perfectly with no issues.
To anyone else considering the upgrade, I would wholeheartedly recommend it, the performance of the machine for encoding video etc. has doubled.
It wasn't actually too difficult, on a scale of 1 to 10, with 10 being the hardest I would put it at about a 4.
door Deel
I have the same iMac core i 3 3.2 27" with ati radeon 5670, i saw the Jooyoung Park got it working whit core i7 870, i want to know if his graphic is the same 5670. bought i7 780 and will receive next friday, so i want to know if i just replace and will work. sorry for my english.
Thanks.
door Deel
Answering my question: Yes it works I had a 27 core i3 550 and replaced with i7 870, just replaced and it works nice.
door Deel
I did the same, just replace and your iMac will work faster and nice...
door Deel
3 commentaren meer tonen
Did you try to change it? Did it work?
1 Opmerking:
Yeah, good working!! I had i3 (550) model replaced i7 (870) cpu. It was good working since replaced.
i7 870 cpu just lower $300!! Good luck!!
door Deel
Did you just do a straight up swap or was there anything extra involved(i.e. firmware or graphics)?
2 opmerkingen:
You should be able to just swap it and detect it and play.
door Deel
Yeah, just replaced and perfect work. Don't worry about that!
door Deel
I will be updating my iMac mc510ll/a, intel i3-550, ati hd5670 to i7-870, will let all of you know, ok! would appreciate any input from Jooyoung Park or anybody
Update
So finally yesterday, I got my i7-870 processor and I was able to just swap the i3-550 in my iMac 27'' mid 2010, 11,3 to i7 was just like Renato said plug and play, thank you guys, I have successful upgrade on my iMac and I'm very please to report that the performance on my iMac has been unleashed, I'm talking about mostly about my video decoding tasks, this processor is a beast. Heres is the system in detailed after upgrade, also I used arctic silver as the heat transfer compound as advised.
Hardware Overview:
Model Name: iMac
Model Identifier: iMac11,3
Processor Name: Intel Core i7
Processor Speed: 2.93 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 12 GB
Processor Interconnect Speed: 4.8 GT/s
Boot ROM Version: IM112.0057.B00
SMC Version (system): 1.59f2
You won't be able to go to Sandy Bridge. The i3 550/i5 650 /i7 860/870 are all socket 1156, Sandy Bridge chips (i5 2310/2400/21500, i7 2600) are all socket 1155 - that'd be a different logic board.
In theory, you could start with a new 2011 version with the i5 quad core and upgrade it to the i7 sandy bridge, but that's quite the expensive upgrade to do on a machine if you don't have a reason to.
The 2010 iMac's are 1156 - Pre-SandyBridge only. If someone proves that wrong, please let me know!
I did the i3 550 to i7 870. The logic board reads out the process just fine, however my fans are running at full speed and the hardware tests is returning a 4sns....
1 Opmerking:
Definitely worth it, the fans work just fine. I use fan control by Michael Denman. With a bit of adjusting you can set what temperature the fans will start to increase in speed from their minimum settings.
door Deel
thanks everyone for the quick reply.
just making sure.. upgrade from iMac 11,2 (21,5") Core i3 550 to Core i7 with TDP 95w, right?
i heard that would have some problem due the higher TDP, so i was afraid to get stuck with the i5 680 as higher upgrade possible.
if anyone could suggest a good store with a nice price to buy, i would appreciate.
thank you guys!
Hi,
Im wondering the same as Thomas Goss:
Change my i3-540 with an i7-xx
Anyone tried?
4 opmerkingen:
i7 doesnt wonk on 21.5 iMac. internals aren't the same. The logic board, GPU and power supply are different.
door Deel
Hello Renato,
You said before:
" after 1 year i3 to i7 870 working very nice
me too. No problem. "
So, you changed from i3 too. Whats the diference between yours and mine? 540 and 550 are almost the same, no?
Are you from Brasil?
door Deel
Sim Daniel sou de São Paulo eu peguei como você disse que seu iMac é idêntico ao do Thomas o que difere do meu é que o seu é de 21.5 polegadas o meu de 27 sendo que o de 27 tem uma fonte mais potente e suporte a um tdp maior também. Outra coisa que impede o upgrade para um i7 nesse iMac de 21.5 é o bloqueio que a Apple faz via EFI e isso não ocorre no de 27 porque a placa lógica do i3 550 é a mesma do i7 870 soquete LGA 1156 sua placa também possui o mesmo soquete porém uma EFI diferente.
door Deel
Poxa. Tava tão animado.
Entao esquema é vender ele e comprar um novo... =(
door Deel
Renato,
Pelo que vi no site da Apple, a EFI é igual:
iMac (27-inch, Mid 2010) iMac11,3 IM112.0057.B01 (EFI 1.8)
iMac (21.5-inch, Mid 2010) iMac11,2 IM112.0057.B01 (EFI 1.8)
http://support.apple.com/kb/ht1237
Então no caso o que impossibilita é que o i3 ou i5 (dualCore) tem tdp de 73 w e o i7 tdp de 95 w
I would suggest putting in N particles in each core rather than dividing up N amongst 8. I am actually going to take the liberty of lifting your code and running it on my cluster
Travel Teluk Kiluan
I don't think an i7 will work personally. There's quite a power difference (Max TDP 73 W for the i3-540 and Max TDP 95 W for i7-780 respectively).
Secondly it's believed that the Mac somehow utilizes the i-series Clarkdale Integrated Graphics Processor. The i7 mentioned above doesn't have that function.
Score -1
Voeg je antwoord toe
Jooyoung Park zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 37,643
