Ga door naar hoofdinhoud
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
369 Vragen Bekijk alle
Why phone overheats after repair?
i recently replaced the screen on my phone with a full replacement screen with frame and lcd assembly. The phone then worked fine for two hours and now it just says its overheating. no problems before the repair. but now phone is useless. any ideas???
Is dit een goede vraag?
Score 1
3 opmerkingen
Where did you get the screen from? Did you check if the new screen replacement has the thermal pads installed on it just like the original screen had?
Also you maybe should of asked Samsung before for pricing as they may be cheapest for screen replacements.
door
Samsung won't fix it I called them first and yes it has the pads it was from a Samsung direct supplier
door
Had a customer come through after sending it in to Samsung for repair. It came back broke again! And refused to refund him!
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Although painful, after you've just buttoned the phone, but you gotta. Check inside and see if anything is noticeably wrong or different. You may have damaged something during the repair
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
The heat comes from under one of the gaurds over the chips. I was very careful with the logic board. I made sure to use all precautions that i could.
door
Could be the display is drawing too much power. You may want to exchange it for an different one. I've seen that happen before
door
Voeg je antwoord toe
cellrepair zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 2,963
