Ga door naar hoofdinhoud
This is the Acer Chromebook launched in 2014 and uses the ChromeOS. The model number is CB3-111-C670 .
Wifi is disabled and cannot be re-enabled
So recently my Chromebook was not connecting to any networks. When I went to look at the connections, it said that the Wi-Fi was turned off, and the button to turn it on was not present at all. Upon clicking on 'Settings', the Wi-Fi network was listed as 'Disabled', but when I went to click on it, it does not give any options to re-enable it. What's wrong with it?
Is dit een goede vraag?
Score 11
5 opmerkingen
Why my chtome book is not connent to wfi
door
Why. Chrombook is nor connent to wfi
door
Same issue here. I've tried to power off, powerwash and reset many times without much success. Then I took the laptop to my local PC shop. The technician opened the back, removed the Wifi card, cleaned it and screwed it back tightly and it’s been working fine since then.
door
It's may chrome os's bug, try to press ctrl + alt + T open the crosh tab then enter "rollback" to rollback to previous version.
door
Took out wifi card and cleaned it and re-seated it, fixed the problem.
door
Voeg een opmerking toe
9 Antwoorden
Gekozen oplossing
After dealing with this issue for years on my daughters school Chromebook (ASUS brand) I finally was able to fix the issue by opening it up and placing a tiny paper washer underneath the screw to raise the wireless card just slightly, now it works great. To verify unscrew the wireless card but leave plugged in, it should sit at a slight angle in the connector, then power up and see if it works.
Was dit antwoord nuttig?
Score 7
5 opmerkingen:
I just tried doing this with my daughter's acer chromebook and it worked great! I used a tape to fix it in place. Thank you!
door
Did this with my lenovo chromebook and it fixed the problem!
Before I was losing wifi multiple times an hour and restarting it was the only way to get connection again. After sticking two tiny pieces of index-card cardboard under the wireless card, it's been going strong for 24 hours!
This post combined with this video on how to take apart a chromebook was the fix for me: https://www.youtube.com/watch?v=ejC_h-l7...
door
I also did this with my Acer Chromebook. I took the back off and unscrewed the screw holding the wireless card down and when I restarted the Chromebook, it actually worked!!! It’s a lot simpler than it sounds. Thank you so much
door
Acer Chromebook where wifi toggle would not turn on. Keeps showing off after reboots. Took cover off and removed wifi card. Used a piece of electrical tape folded up, and used a small hole punch for the screw to go through. Closed it back up and booted up. Wifi working now! Thank you!
door
Thank you for sharing this!! I've been looking for a solution for quite a long time to enable Wifi in my Acer Chromebook and I finally found it.
door
I had this exact problem. I even took it to a pc repair shop and they said the WiFi chip may be faulty but they replaced it and it still didn't work! I bought a cheap ethernet to usb cable from eBay and plugged it in and now it's working! The WiFi is still disabled but I can use it now through plugging it into the ethernet cable at home.
Score 2
I went to get this fixed and they said it needs a hardware reset this is basically what they did : https://www.youtube.com/watch?v=ejC_h-l7...
Score 1
1 Opmerking:
How much was the repair?
door
Abrirla, quitar la tarjeta wifi, desconectar la bateria, esperar 1 minuto sopla ligeramente en el puerto de la tarjeta wifi, conectala, conecta la bateria…. y taraaan!! ya jala
Score 1
I took mine to a repair shop out of frustration. In less than 5 mins, the assistant unscrewed the case, removed the WiFi card, cleaned up card & port. screwed everything back. No issue with the WiFi since then.
Score 1
Same problem here. This worked for me.
https://productforums.google.com/d/msg/c...
1 Opmerking:
door
Try to put the date and time correct if you dont have It yet, and let me know on its goes!
well i installed a vpn and it stop doing this as freqent
I have this problem too follow these steps to fix it
1.open kernel of chrome os
2.select all almost name kernal
3.press enter and get enter till options are over
4.save change and problem solved
Voeg je antwoord toe
supadude543 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 78
Afgelopen 30 dagen: 381
Altijd: 72,566
