My NutriBullet doesn't stay on
I just got my nutribullet rx, and it does not stay on. When I hit the power button, the blue ring turns on, but right when I release the light turns off. The blender works when I hold the power button down, but it doesn't stay on.
Is dit een goede vraag?
Problem my blue light won't cut off when xlnutrition is off. The only way blue light goes it must be unplugged from the wall socket
door Ann Walker
I had same problem... Just blue light button wont turn off - and it doesnt affect motor until whole unit is unplugged from the wall socket... I checked for answers online - but no solution or advice...
I was experimenting with it while being disconnected from the wall socket and then i turned whole unit upsidedown (ofc without a cup being attached into it) and then pressed the blue power button several times - but i was trying to feel the actual "click" sound and then pushed the button from various angles - like pushing it under the angle - not straight push but from different sides and felt small change in the click sound (it seemed a bit different)... Then i took the unit in normal position and plugged it into the wall and the Blue power button started working properly!
If you have additional questions feel free to ask
door Branko Tadic
Omg thanks a lot! That “hit” really helps me solve the problem! Thank you a lot!
door Joy Zhou
