How to Reinstall EMI Shield after cleaning
iphone 5, I have reason to believe that the logic board has water damaged parts under the EMI shield.
how would I reinstall the shield after removing and cleaning?
Is dit een goede vraag?
Clean up or flatten out all the shield solder joints with a soldering iron and wick if you need it. Slip the shield back on and use an iron to solder the points again. You don't need to do a perfect job on every single joint. It helps if you try an avoid prying/bending the shield during removal.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 94
1 Opmerking
Read the answer below.
door icaremore
