Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
Temperature warning after lcd connector replacement
Hello, my phone has a ghost touch and i tried to replace the screen but it didnt work. After that i realized the problem is from the connector of the lcd. So i changed it.
After the lcd connector replacement my screen doing fine but it always show battery temperature warning.
I tried change the battery with my used battery it get rid the warning. But the battery only has 100mAh
I tried change the battery six times but it doesnt solve my problem. So any suggestion for my problem?
Thanks before
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
temperature warnings are from the pmu thermistors. camera faults normally are the fault. disconnect the cameras and see if the fault arises
front camera!
Was dit antwoord nuttig?
2 opmerkingen:
Can i try it with different set of screen? Because i have another screen which is still has a complete part
door
Didnt work change the full of front panel or front camera itself, the pop up warning still there
door
change the Battery was the solution for me.
Voeg je antwoord toe
Giri firmansyah zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 116
